Here are the parts
Replacement parts for WHIRLPOOL LER4624BQ2 | AppliancePartsPros.comHere is the wiring diagram
http://www.servicematters.com/docs/wiring/Wiring%20Sheet%20-%203401728.pdf[COLOR="Blue"]I Need To Find Correct,heating Part For 120/240 And Where To Put Right Part In Where Located[/COLOR]
Not sure what you mean as the heating element is 240 volts only.
Also if the problem is just no heat there are a number of things which can cause this.
First make sure you have the proper power to the unit.
Try flipping the breaker off/on slowly a couple times, sometimes you can loose half the line without actually tripping the breaker.
If this does nothing, check the voltage at the plug
L1 to L2 should be 240 volts
If OK
If OK
Be careful as 240 volts is lethal !!!
If OK then most likely is a thermostat, a thermal cut-off or the heater.
