ramonamahoney@rocketmail.
#1 Posted : Saturday, January 16, 2010 2:21:00 PM(UTC)
I Need To Find Correct,heating Part For 120/240 And Where To Put Right Part In Where Located
#2 Posted : Saturday, January 16, 2010 2:23:05 PM(UTC)
FOR ELECTRIC 15YEAR OLD DRYER.
#3 Posted : Sunday, January 17, 2010 1:48:00 AM(UTC)
Here are the parts
Replacement parts for WHIRLPOOL LER4624BQ2 | AppliancePartsPros.com
Here is the wiring diagram
http://www.servicematters.com/docs/wiring/Wiring%20Sheet%20-%203401728.pdf
[COLOR="Blue"]I Need To Find Correct,heating Part For 120/240 And Where To Put Right Part In Where Located[/COLOR]
Not sure what you mean as the heating element is 240 volts only.
Also if the problem is just no heat there are a number of things which can cause this.
First make sure you have the proper power to the unit.
Try flipping the breaker off/on slowly a couple times, sometimes you can loose half the line without actually tripping the breaker.
If this does nothing, check the voltage at the plug
L1 to L2 should be 240 volts
If OK
If OK
Be careful as 240 volts is lethal !!!
If OK then most likely is a thermostat, a thermal cut-off or the heater.
geller1
#4 Posted : Thursday, January 28, 2010 6:34:06 PM(UTC)
geller1
:):(:mad:I want to find the way to check the igniter to heat the dryer I cannot find a maual for this dryer on line. The dryer only blows cold air. Can anyone help? Thank you.
Barry Geller
joymaker@optonline.net
#5 Posted : Friday, January 29, 2010 12:33:05 AM(UTC)
geller1
Please start a new thread using "Post New Topic" at the start of this forum section.
Adding to another person's thread when the unit is a different model and a different dryer type just confuses things.
