AppliancePartsPros.com
Appliance Repair Help
Washer Repair
Whirlpool Washer won't agitate or spin makes Grinding noise
Washer makes grinding noise when it's suppose to agitate or spin. On high spin noise is louder, on low spin not as loud. Water pumps out ok. Please help - not sure what to check first. I have the shell off now...waiting. Thank you, Lady Lee :confused:
Tilt the washer to the back and look closely to the motor, the coupling from motor to trans may be broken.
Originally Posted by: Lady Lee  Washer makes grinding noise when it's suppose to agitate or spin. On high spin noise is louder, on low spin not as loud. Water pumps out ok. Please help - not sure what to check first. I have the shell off now...waiting. Thank you, Lady Lee :confused:  Washer is making a loud noise while in spin cycle? Why?
:mad: Washer is making a loud noise while spinning? Why?
Hi Alan,
In order to provide most accurate advise we need the complete model number of the washer.
Washer Repair
