Heres my problem. After turning motor works but water dose not come on at all. Here's what i came up with. Have 120v going to the start switch in door. With start switch closed [on] have 120v going to control switch[operates functions ] 120v then goes to a round timer no volts leaves it. Wire from round timer goes to a switch beside start switch [both operate at same time ] wier leaves that switch and goes to water valve. No voltage at water valve. any help thanks Gerald:confused:
A Model Number may help others help you |
THIS FORUM IS DEAD!!!!!!! |
Originally Posted by: denman  A Model Number may help others help you OK thanks for your input.
