Is there any specific test that can be done with say, a multimeter, or is something specialized needed requiring a technician to come in and take a look?
BTW, thanks for all your help so far.
I would order a new motherboard AP4436216 and evaporator motor AP3875639
Should I get the motor without the thermistor (AP3875639), or the one one with the thermistor (AP3191003 )?
Originally Posted by: psc23ngn  Just ran the fridge for 45 minutes (had shut it down last night as it is not doing anything useful anyway) and yeah, the compressor seems to be NOT running. Cold to touch with no humming etc, and the metal tubes attached are cold too.
Does the compressor need to be replaced, or can more checks be done to isolate the problem as it might be some other related component? I am hoping that I don't have to call a pro and save some money in these times ;-) Is the condenser motor running or not? If the compressor is not running and condenser motor is not running, then its not calling for cooling. I know you said the compressor is not running, but what about the condenser motor right beside it?
Replaced the motherboard. Refrigerator is working again.
Very good and you didn't listen to the "static" from John .
Happy. Stop being an asshole.
Foul language is barred fom this site, confine your comments to constructive ones only. I will monitor your comments and will see if you provide comments worthy of this site.
Thanks for your help, Richappy.
Thanks for your support psc23ngn, I had to correct most of John's responses to msgs sent in and he understood he was in error.
