mark6118
#1 Posted : Tuesday, January 26, 2010 10:24:54 AM(UTC)
mark6118
I have a bosch shv4303uc. I believe my dishwasher is stuck in flood mode.
The drain pump stays on will not switch to wash mode.
what i did to diagnose.
Inside Removed strainer and bottom plate, to look for water.
removed a plastic cover which shields a propeller, i believe that directs water into a little hole that has a one way valve to take water but not expel.
I took a Q-tip to push the one way valve and half of cup water came out.
i removed the water, put the plastic cover back on the propeller.
I closed the dishwasher door and hit the rinse cycle, but still stuck in drain mode.
filled it up with half of gallon of warm water, repeated the process, I can hear the water drain but still stuck in drain mode.
I'm open to any opinions. and how do i reset this model.
mark6118
#2 Posted : Tuesday, January 26, 2010 11:09:03 AM(UTC)
mark6118
after surfing some of your posts,
I found a way to reset SHV4303UC
Hold down power scrub and reg wash buttons, hit the power button.
Let the test run for 60 sec.
Before I did the test, filled half of gallon of warm water.
The dishwasher continues to stay in drain mode. 99% of the water is gone,
except where the propeller is.
mark6118
#3 Posted : Tuesday, January 26, 2010 12:29:21 PM(UTC)
mark6118
I've talked to bosch and they sent me a diagram.
UserPostedImage
Recap
I remove the plastic lid (16 5263) to expose the propeller (16 7082).
the one way valve that I'm talking about is (16 5262).
If any one knows what i should replace, please any information would be grateful.
