I have a bosch shv4303uc. I believe my dishwasher is stuck in flood mode. The drain pump stays on will not switch to wash mode. what i did to diagnose. Inside Removed strainer and bottom plate, to look for water. removed a plastic cover which shields a propeller, i believe that directs water into a little hole that has a one way valve to take water but not expel. I took a Q-tip to push the one way valve and half of cup water came out. i removed the water, put the plastic cover back on the propeller. I closed the dishwasher door and hit the rinse cycle, but still stuck in drain mode. filled it up with half of gallon of warm water, repeated the process, I can hear the water drain but still stuck in drain mode. I'm open to any opinions. and how do i reset this model.
after surfing some of your posts, I found a way to reset SHV4303UC Hold down power scrub and reg wash buttons, hit the power button. Let the test run for 60 sec. Before I did the test, filled half of gallon of warm water. The dishwasher continues to stay in drain mode. 99% of the water is gone, except where the propeller is.
I've talked to bosch and they sent me a diagram.  Recap I remove the plastic lid (16 5263) to expose the propeller (16 7082). the one way valve that I'm talking about is (16 5262). If any one knows what i should replace, please any information would be grateful.
