1955fordnut
#1 Posted : Sunday, January 24, 2010 8:03:36 PM(UTC)
1955fordnut
is there a reset button on this because it just flat quit working light dont even work in drum anylonger. any ideas
1955fordnut
#2 Posted : Tuesday, January 26, 2010 7:13:13 AM(UTC)
1955fordnut
is there a fuse or switch wire that i can jump to check for the problem. I think it may be the timer button is there any of those wires i can use a jumper to test and bypass the timer button?
oilslinger53
#3 Posted : Tuesday, January 26, 2010 2:49:09 PM(UTC)
oilslinger53
I'd Check the doorswitch. Could be the cord. Sometimes the receptacles have loose blades. Light should still work if the timer switch is bad. Try starting the dryer while jiggling the plug.
1955fordnut
#4 Posted : Tuesday, January 26, 2010 7:45:44 PM(UTC)
1955fordnut
Ok jiggled cord even went and got new cord no juice, no light tried bypassing door switch no luck there either, any other ideas anyone
Guest (5)
Dryer does nothing (Dryer Repair)
by Joe966 8/24/2016 8:35:49 AM(UTC)
DRYER does nothing (Dryer Repair)
by mar1270 5/1/2014 10:47:39 AM(UTC)
Roper dryer does nothing (Dryer Repair)
by Influencer 7/17/2013 3:01:53 PM(UTC)
by pilsner 9/4/2012 10:49:26 AM(UTC)
by rob2010 7/31/2010 1:18:26 PM(UTC)
by smallies 10/21/2008 6:42:54 PM(UTC)
Whirlpool dryer does nothing (Dryer Repair)
by Jon P 8/6/2008 6:44:24 PM(UTC)
