ijh
#1 Posted : Saturday, January 23, 2010 7:37:44 AM(UTC)
ijh
Washer still working, but during the spin cycle it shakes terribly, sounds horrible and smells kinda burny. Is this probably a problem with the motor coupler and is it something the homeowner can fix instead of a costly repair service?
appliGuy
#2 Posted : Saturday, January 23, 2010 8:56:25 PM(UTC)
appliGuy
If the coupler was broken the unit would not spin. Do you feel vibration in the floor when it is spinning?
#3 Posted : Sunday, January 24, 2010 3:56:08 AM(UTC)
Are all the feet touching the floor?
ijh
#4 Posted : Sunday, January 24, 2010 5:04:01 AM(UTC)
ijh
Thanks for your replies. I guess it's not the coupler then, cause it can still spin at this point. It shakes so bad now, it usually moves across the floor a couple inches. All feet are on the floor. The only time it sounds better is if we run an extremely small load- of say only a few items. I know it sounds like a classic imbalanced load of items, but we are very careful about that, since the noise and moving across the floor began. This washer is supposed to be capable of a super large load of clothes.
#5 Posted : Sunday, January 24, 2010 10:02:10 AM(UTC)
I would pull off the outer cover and check suspension springs and look for a missalighned skate board under the tub, compare the two sides.
