Mike-mcd
#1 Posted : Wednesday, January 20, 2010 4:44:50 PM(UTC)
Mike-mcd
Inner glass on oven dooor is cracked/broken. need to replace. I believe p/n for glass is : AP4282886. Unsure is additional parts i.e oven door pad and liner, gasket, etc are needeed to complete job and if glass p/n is inner glass or outer glass. Advice appreciated
#2 Posted : Thursday, January 21, 2010 1:09:31 PM(UTC)
The model number you posted does not come up. Verify and repost it.
Mike-mcd
#3 Posted : Friday, January 22, 2010 3:58:41 AM(UTC)
Mike-mcd
Posted incorrect Model Number for oven. Correct Model # ARG7600WW
#4 Posted : Friday, January 22, 2010 12:51:33 PM(UTC)
Mike,
The correct inner glass Part number: AP4279859
I do not think you'll need any additional parts unless something else broken.
Here are the breakdown diagrams and Replacement parts for AMANA ARG7600WW Range - S/c S/i Ddraft Gas | AppliancePartsPros.com
Mike-mcd
#5 Posted : Tuesday, February 2, 2010 4:13:44 PM(UTC)
Mike-mcd
Mike,
Thanks for your help, much appreciated. part # you listed is different from one listed at site when I placed order. Appliance Parts Pro listed part as AP4282886.
#6 Posted : Thursday, February 4, 2010 10:56:28 AM(UTC)
Actually there are two part numbers listed and in such situation you had to call the customer service to verify the correct part number.
Broken Oven Door Glass (Oven Repair (including Ranges and Cooktops))
by JasonKaleta 5/1/2010 9:50:29 AM(UTC)
Broken oven door glass (interior) (Oven Repair (including Ranges and Cooktops))
by vstouffer560 4/13/2009 1:00:23 PM(UTC)
Do I need to fix it? Broken Oven Door Glass (Oven Repair (including Ranges and Cooktops))
by cjrlauve 2/18/2009 8:50:09 AM(UTC)
broken oven door glass (Oven Repair (including Ranges and Cooktops))
by abbyrubin 11/28/2007 2:35:32 PM(UTC)
