mmmharly
#1 Posted : Tuesday, January 19, 2010 7:32:41 AM(UTC)
mmmharly
Just purchased a used front end loader. Washer worked when we looked at it - transported it home when we pluged it in the power button will not engage. Have water going to it , checked power to it , checked for broken wires - none found by site. checked for loose connections. the ccu clicks when the unit is plugged in.
sidfink43
#2 Posted : Wednesday, January 20, 2010 12:48:21 PM(UTC)
sidfink43
If power is getting to the CCU then it is probably bad. Use the diagnosis mode testing in this service manual to see if you can get it into test mode and get a confirmation.
https://secured.whirlpoo...61b1ba/$FILE/8178558.pdf
Washer will not power up (Washer Repair)
by KernH 1/14/2016 9:31:30 AM(UTC)
Dishwasher will not power up (Dishwasher Repair)
by Richard Yunker 11/20/2012 7:44:21 AM(UTC)
lg washer will not power up (Washer Repair)
by hokutori 11/9/2012 5:00:17 PM(UTC)
by jettechaero 2/10/2012 6:35:53 PM(UTC)
