dwayne
#1 Posted : Monday, March 17, 2008 12:41:59 PM(UTC)
dwayne
When I load my dishwasher and turn it on, sometimes it may come on at that exact time. Others times I may turn it on and it does not do anything for days on end. What part may need to be replaced?
#2 Posted : Tuesday, March 18, 2008 1:58:19 PM(UTC)
Hi Dwayne,
Does the "cycle on" light comes on every time?
Does the dishwasher malfunction on any cycle?
dwayne
#3 Posted : Wednesday, March 19, 2008 5:24:01 AM(UTC)
dwayne
the cycle light only comes on when works
#4 Posted : Wednesday, March 19, 2008 1:12:46 PM(UTC)
Hi Dwayne,
Hi Dwayne,
You did not answer on the above question.
dwayne
#5 Posted : Wednesday, March 19, 2008 2:47:29 PM(UTC)
dwayne
once it comes on if it does it works find through all the cycles
dwayne
#6 Posted : Wednesday, March 19, 2008 2:57:54 PM(UTC)
dwayne
when the cycle light is on the dishes washer works when turn to the on position but most the time in the on position or run the cycle won,t come on that,s on all settings
#7 Posted : Wednesday, March 19, 2008 2:58:33 PM(UTC)
Sorry, you probably did not get my question right. I meant cycles chosen on the selector switch on the left side.
dwayne
#8 Posted : Friday, March 21, 2008 6:15:25 AM(UTC)
dwayne
my dishes washer malfunction on all cycle when it,s not working.
#9 Posted : Friday, March 21, 2008 5:50:41 PM(UTC)
Hi Dwayne,
The first thing I would check is the door switch (#803 on the break down diagram) and wires.
If there is nothing wrong then the problem is a bad timer.
- The part number for the door switch is AP2038824
- The part number for the timer is AP2039749
Here are the break down diagrams for the GE dishwasher Model EDW1500G00BB
Guest (5)
