sstankss
#1 Posted : 15 years ago
sstankss
Need to know what part I need. The washer won't shut off the water when the water reaches the proper level. Tried all 3 levels. Tried all 3 wash cycles. It only stops filling if I turn the timing knob to "Spin".
sidfink43
#2 Posted : 15 years ago
sidfink43
You may not need any parts. Try cleaning out the plastic tube that connects the water level pressure switch and the tub.
sstankss
#3 Posted : 15 years ago
sstankss
:D Thanks. I found that the tube had slipped off the Level Control nipple. Reseating it fixed the problem. Thanks for your reply.
sidfink43
#4 Posted : 15 years ago
sidfink43
Great, glad you got it fixed and thanks for the update.
