Need to know what part I need. The washer won't shut off the water when the water reaches the proper level. Tried all 3 levels. Tried all 3 wash cycles. It only stops filling if I turn the timing knob to "Spin".
You may not need any parts. Try cleaning out the plastic tube that connects the water level pressure switch and the tub.
Originally Posted by: sidfink43  You may not need any parts. Try cleaning out the plastic tube that connects the water level pressure switch and the tub. :D Thanks. I found that the tube had slipped off the Level Control nipple. Reseating it fixed the problem. Thanks for your reply.
Great, glad you got it fixed and thanks for the update.
