my control panel is stuck on lock. i tried turning the power on and off but the panel is still locked. what should i do. my washer did not come with an owners manual to look up trouble shooting
thank you, i was able to hold the end cycle button down for three seconds, that unlocked the controls. this info helps because i get an f06 code often
thank you. i was held the end cycle button down for 3 or more seconds and that unlocked the control panel. the info you sent is good to have because i get an f06 code often.
