meatballkf
#1 Posted : Saturday, January 16, 2010 3:51:22 AM(UTC)
meatballkf
my control panel is stuck on lock. i tried turning the power on and off but the panel is still locked. what should i do. my washer did not come with an owners manual to look up trouble shooting
sidfink43
#2 Posted : Sunday, January 17, 2010 3:48:31 PM(UTC)
sidfink43
See if you can use the info in this tech sheet to put it into diagnosis mode.
http://www.servicematters.com/d...0Sheet%20-%208182277.pdf
If it remains locked you will have to try replacing the central control unit.
meatballkf
#3 Posted : Tuesday, January 19, 2010 4:44:03 AM(UTC)
meatballkf
thank you, i was able to hold the end cycle button down for three seconds, that unlocked the controls. this info helps because i get an f06 code often
meatballkf
#4 Posted : Tuesday, January 19, 2010 4:45:39 AM(UTC)
meatballkf
thank you. i was held the end cycle button down for 3 or more seconds and that unlocked the control panel. the info you sent is good to have because i get an f06 code often.
