Hi my dryer makes a humming sound when I push the start button but doesn't actually do anything. Its like the sound of the motor wanting to move but can't if you can understand what I'm saying. Its like that electric sound of a motor not doing anything. but when I let go of the start button it doesn't do anything. If you could get back to me and let me know what is causing this I'd greatly appreciate it! Thank you for your time!
Here are your parts Replacement parts for AMANA ALE643RAW Dryer - Ele | AppliancePartsPros.comIf the unit is blowing air but just the drum does not turn, it could be a broken belt. Try turning the drum by hand. Should turn fairly easily. If not could be the drum is jammed for some reason. You may want to try this on a couple other dryers to get a feel for it. If it is difficult to turn run your fingers around the back and front of the tub to machine seal. To see if something has jammed between the tub and frame (bra wires are famous for this). Be careful in case the object is something sharp. If nothing is jammed in there you will have to open it up and find the cause. If it rotates OK. This may take 2 people Open the door Manually hold the door switch closed Push the start button and manually rotate the drum in the correct direction. Watch your knuckles in case it starts up. If it does start up, odds are high that you need a new motor. Could also be that the motor is jammed solid with lint and this is preventing the Start/Run centrifugal switch from resetting (the unit is trying to start with out the motor's start winding in circuit. |
THIS FORUM IS DEAD!!!!!!! |
