vpolitano
#1 Posted : Monday, January 18, 2010 9:37:23 PM(UTC)
vpolitano
Having an issue with our maytag Dryer, It's been working fine, this past weekend i needed to change the 2 rollers and belt. All went fine, but soon noticed that the cloths where taking to long to dry. Took the front panel off and noticed that when the dryer is started, within 30 seconds the ignitor glows bright orange, within 15 - 20 seconds gas fires and the flame comes on, as soon as that occurs i can see the ignitor starting to go dim, then within seconds the flame goes out. Eventually in about 15 - 20 seconds i hear a click, the shortly afterwards it cycles again, ignitor, flame and all goes out starting with the igniitor diming.
I suspect the coil valves, though the flame and Hi-temp could be suspect also i am thinking, any suggestions or thoughts on what this could be ?
thanks in advance
jvbrooks
#2 Posted : Saturday, February 6, 2010 10:25:10 AM(UTC)
jvbrooks
I'm having the same issue with my Maytag LDG712, did anyone reply to the cause and/or offer a soution.
Thanks,
Jason
vpolitano
#3 Posted : Thursday, February 11, 2010 7:16:49 PM(UTC)
vpolitano
Hi Jason,
I never did recieve a reply, but i did change out the gas valve solenoid coils and that fixed it.
Good luck
vito
Guest (4)
