wannabe
#1 Posted : Tuesday, August 14, 2007 9:41:00 AM(UTC)
wannabe
during initial soak (any temp), water cuts off before filling to the appropriate level
should I replace the water level switch?
should I attempt to test my old one first?
thanks
#2 Posted : Tuesday, August 14, 2007 9:37:57 PM(UTC)
wannabe
The first thing I would do is to check the water level on the different cycles. If it works fine on all other cycles then it's possible the water level should be lower on the soak (just in case check the "Use and care" book).
If this is not the issue then drain out the water completely, disconnect the clear hose form the water level switch, blow some air through the hose and reconnect it. Check the water levels again. If it's still wrong then replace the water level switch.
The part number for the new water level switch is AP3020315
Good luck.
wannabe
#3 Posted : Wednesday, August 15, 2007 8:30:51 AM(UTC)
wannabe
Thanks. I'll try that. Is there an easy way to disconnect this switch from the front panel? I couldn't seem to locate the correct release tab.
wannabe
#4 Posted : Thursday, August 16, 2007 6:33:57 AM(UTC)
wannabe
Gene, you're the man. I took the hose off and blew through it. Seemed clear. Went ahead and took the switch apart and played with the rubber diaphraghm. My wife called to tell me how happy and impressed she until I made sure to give you credit. I'll buy a new switch if it acts up again.
THANK YOU.
wannabe
#5 Posted : Wednesday, August 22, 2007 11:39:23 AM(UTC)
wannabe
or not :confused: . I think I'll replace this and see what happens.
#6 Posted : Monday, August 27, 2007 2:15:03 PM(UTC)
Hi wannabe
Good luck and keep me updated, please.
wannabe
#7 Posted : Tuesday, August 28, 2007 4:56:18 AM(UTC)
wannabe
Bought the part from this site (arrived very quickly). Washer seems to be working again and wife is happy (as she can be).
#8 Posted : Tuesday, August 28, 2007 8:02:33 PM(UTC)
Good job, wannabe!
Amana washer not filling properly (Washer Repair)
by carcajou 5/12/2023 10:53:05 AM(UTC)
GE dishwasher not filling and other problems (Dishwasher Repair)
by Guest 4/14/2022 3:40:35 PM(UTC)
dishwasher not filling with water...already changed water inlet valve (Dishwasher Repair)
by jbonez 5/25/2021 5:32:22 PM(UTC)
KitchenAid KUDS30IXBLA Dishwasher Not Filling Up With Enough Water (Dishwasher Repair)
by navagator 2/6/2021 3:49:58 PM(UTC)
dishwasher not filling mdb5600awb (Dishwasher Repair)
by sac65849 1/4/2021 8:56:23 PM(UTC)
Speed Queen washer not filling (Washer Repair)
by CraigRich 4/7/2020 1:39:07 PM(UTC)
KitchenAid KUDR01TJBT0 DISWASHER not filling (Dishwasher Repair)
by TFGTech 1/21/2020 3:17:30 PM(UTC)
GE Dishwasher not filling with water (Dishwasher Repair)
by shawnkocher508 10/31/2016 12:12:32 PM(UTC)
Hotpoint Washer not filling for rinsing (Washer Repair)
by frank203 12/5/2015 9:02:57 AM(UTC)
Washer not filling and no hum (Washer Repair)
by angellewis 9/21/2015 2:15:33 PM(UTC)
GE Cafe Dishwasher not filling (Dishwasher Repair)
by Moai Mat 9/6/2015 5:08:45 PM(UTC)
KitchenAid Dishwasher not filling with water (Dishwasher Repair)
by njallison@juno.com 7/16/2015 5:58:31 PM(UTC)
GE Washer not filling (Washer Repair)
by enrietta4 7/19/2014 4:51:45 AM(UTC)
Kenmore Dishwasher not filling up with water (Dishwasher Repair)
by Bukwas 4/25/2014 10:20:04 AM(UTC)
Bosch dishwasher not filling (Dishwasher Repair)
by kywingnut 11/15/2013 7:44:47 AM(UTC)
