The Kitchenaid washer doesn't agitate but will go through the spin cycle. What do I need to fix the problem? model # KAWS700GQ0
Probably your agitator cams, called "dogs" are worn out. An easy and inexpensive fix. Here is the part Part number: AP3138838
