Rank:: Member
just purchased a washer with a leak I removed everything on the bottom up to the tud, there is a bolt that turns the moter that needs to be removed to see if there is a seal I need to replace but the bolt won't come out need some help with that. thanks:confused:
Originally Posted by: Gene Hi This Negro I have a problem with my dryer I replace the thermo fuse and the coils but the dryer still gets hot but won't dry clothes stay damp .I think that it might be the thermostat but I'm not sure please can you help me. Thank you
