WORKERBEE
#1 Posted : Friday, January 15, 2010 3:45:06 PM(UTC)
WORKERBEE
Dryer shuts off before timer is finished. I have already replaced the timer unit. What should I check for next? Help?
#2 Posted : Saturday, January 16, 2010 1:44:49 AM(UTC)
The part number comes up as a washer.
If you have to wait several minutes before you can restart the unit, the most likely cause is that the motor is overheating and tripping it's internal thermal protect. You then have to wait till the moptor cools down before you can re-start it.
If the above is true
Try turning the drum in the correct direction. It should turn fairly easily. You may want to try this on a couple other dryers to get a feel for it. Could be the drum is dragging which puts too high a load on the motor.
Open the unit up and check/clean the motor. Could be it is clogged solid with lint.
Check that the motor armature spins freely
If the above are OK, odds are you need a new motor.
Frigidaire Gas Dryer Shuts Off After Less Than A Minute Run Time (Dryer Repair)
by hooter726 10/23/2018 11:54:54 AM(UTC)
Samsung dryer shuts off after 3 minutes (Dryer Repair)
by Mort184 8/2/2017 3:41:15 PM(UTC)
GE Dryer shuts off mid cycle (Dryer Repair)
by nfdmedic 11/14/2016 4:49:22 PM(UTC)
GE dryer shuts off in middle of drying cycle (Dryer Repair)
by archieandveronica@msn,com 4/19/2016 12:23:50 PM(UTC)
GE Electric Dryer Shuts Off Mid-Cycle (Dryer Repair)
by Dynocon 10/22/2015 5:20:00 PM(UTC)
WP Dryer shuts off after 2 minutes (Dryer Repair)
by 44Rick44 9/22/2015 2:47:34 PM(UTC)
Dryer shuts off early (Dryer Repair)
by supertweet 7/2/2015 2:12:17 PM(UTC)
Dryer shuts off after 10 minutes in auto (Dryer Repair)
by loveg65 4/12/2015 12:32:14 PM(UTC)
Dryer shuts off after a couple of minutes (Dryer Repair)
by mrsteelxx 1/28/2015 7:05:23 AM(UTC)
dryer shuts off after a couple minutes (Dryer Repair)
by TowerDSue 8/25/2014 12:40:40 PM(UTC)
gas dryer shuts off after a few seconds (Dryer Repair)
by AAP2014 7/26/2014 5:18:49 PM(UTC)
Dryer shuts off intermitently (Dryer Repair)
by mercosur67 4/16/2014 2:29:27 PM(UTC)
by Abartman 8/14/2013 12:10:52 PM(UTC)
Kenmore 80 series Dryer shuts off intermittently (Dryer Repair)
by fenster88 5/15/2013 9:35:01 AM(UTC)
Dryer shuts off (Dryer Repair)
by Pipsqueke 1/4/2013 5:47:10 PM(UTC)
