TOM901
#1 Posted : Wednesday, January 13, 2010 1:44:04 PM(UTC)
TOM901
Washer will not stop filling on any size load setting. Water will stop if you push the timer button in or unplug the inlet valve. Where do I go from here. Checked tubing from pressure switch good and tight on both ends. Removed tubing no air leaks. Timer will not go to next mode and water will not shut off. How do I tell if it is pressure switch or timer.
PLEASE HELP.
sidfink43
#2 Posted : Friday, January 15, 2010 9:58:40 AM(UTC)
sidfink43
It is very likely the pressure switch. With the machine filling, blow into the tube (plug up the tub opening so it will not spill water all over) and see if you can make the switch cut off and stop the water. If so this will confirm the pressure switch is the problem.
Washer will not stop filling with water (Washer Repair)
by abcps 10/5/2012 11:47:06 AM(UTC)
Washer will not stop filling (Washer Repair)
by Chad993 6/26/2012 7:50:53 AM(UTC)
washer will not stop filling (Washer Repair)
by limey 6/5/2012 9:03:58 PM(UTC)
washer will not stop filling with water. (Washer Repair)
by Louis.nicholls 12/27/2011 8:34:31 AM(UTC)
washer will not stop filling with water (Washer Repair)
by lgoodpaster 10/13/2011 4:37:28 AM(UTC)
Maytag heavy duty washer will not stop filling up (Washer Repair)
by john rodriguez 9/25/2011 11:10:43 PM(UTC)
Washer will not stop filling automatically (Washer Repair)
by rickeystu2 5/28/2011 6:23:39 PM(UTC)
Dishwasher will not stop filling. Leaking on floor. (Dishwasher Repair)
Belarus mpickell 11/15/2010 7:19:31 PM(UTC)
Washer will not stop filling/overflowing (Washer Repair)
by TASALAIZ 6/9/2009 12:26:04 PM(UTC)
Washer will not stop filling and tub leaks (Washer Repair)
by t7433 3/12/2008 11:41:49 AM(UTC)
by Mwaters583 10/26/2007 7:37:58 AM(UTC)
