gerharj
#1 Posted : Wednesday, March 12, 2008 5:10:48 PM(UTC)
gerharj
My frontload washer will not agitate or spin. It will fill with water and pump water out if I manully advance the cycle. I can advance it to refill with water, but I can't manually advance it to agitate or spin.
I replaced the timer (frigidaire # 131802100) thinking it would fix the problem. Do you think it it needs a new speed control board (frigidaire # 131770700)?
Thanks for your help.
#2 Posted : Thursday, March 13, 2008 3:09:09 AM(UTC)
Remove the lower kick panel and pull out the data sheet. You will find a diagnosis for this problem.
Guest (4)
Frigidaire Washer will not spin (Washer Repair)
by luvmylars 4/30/2015 11:33:25 AM(UTC)
Frigidaire washer will not spin towels but will regular clothe loads (Washer Repair)
by jose mulet 7/18/2013 8:05:06 AM(UTC)
by T-worth 1/20/2011 10:38:35 AM(UTC)
frigidaire washer will not spin (Washer Repair)
by herbul73 12/12/2007 5:26:31 PM(UTC)
