gjpowe
#1 Posted : Wednesday, January 13, 2010 9:39:10 AM(UTC)
gjpowe
Good Day!
My clothes mover has been moving not as fast as it did in the past. So I went to take the clothes mover apart but noticed it had this screw that I did not have proper tools to remove so I went to Lowe's to purchase an 'extenstion' for the socket so I was able to remove the screw. But now the Base and the Clothes mover is attached so how do I remove the clothes mover and replace it. Or should I have purchased the 'repair kit' instead of the Clothes Mover? HELP! Is there some special tool I need to remove the clothes mover from the base? Thanks for your assistance!
#2 Posted : Wednesday, January 13, 2010 2:15:27 PM(UTC)
Very likely the problem is a bad agitator dogs, so the repair kit should fix it. The instructions are attached to the reply.
- The agitator repair kit Part number: AP3138838
Here are the breakdown diagrams and Agitator, basket and tub replacement parts for WHIRLPOOL LSR7233DQ0 | AppliancePartsPros.com
File Attachment(s):
Agitator dogs - trust washer.pdf (103kb) downloaded 12 time(s).
chris77
#3 Posted : Monday, February 1, 2010 6:32:55 AM(UTC)
chris77
Will this same repair kit work on Whirlpool model #LQS9010LW2. The top agitator does not work and I don't want to have to replace the entire assembly.
#4 Posted : Tuesday, February 2, 2010 2:33:04 PM(UTC)
Answered here: http://forum.appliancepartspros...properly.html#post181578
