my dryer makes a knocking sound when it is on. what could it be and what parts do i need to fix it?
Sounds like you need new tub rollers.
I believe you're right because I opened the dryer up and saw the right roller slipping side to side some which is making the noise. So could you please tell me what other parts I need besides the rollers? like maybe Roller shaft for drum support roller, right side ? etc.. / .???
The rollers will come in a kit. should have both rollers, shafts and any other misc. hardware.If you send me the model number of your machine i can get the part number you need and send it to you.
the model # is LER5644ANO
ok, for some reason your dryer does not have a full kit. The following are the part numbers you need: 349241T -- 2 pack of drum rollers. 3399506 -- shaft. 339489 -- shaft. There are 2 different size shafts hence the 2 part numbers. hope this helps.
