rmwalker41
#1 Posted : Friday, January 8, 2010 10:53:48 AM(UTC)
rmwalker41
my dryer makes a knocking sound when it is on. what could it be and what parts do i need to fix it?
miketieman
#2 Posted : Friday, January 8, 2010 3:08:53 PM(UTC)
miketieman
Sounds like you need new tub rollers.
rmwalker41
#3 Posted : Saturday, January 9, 2010 9:11:26 AM(UTC)
rmwalker41
I believe you're right because I opened the dryer up and saw the right roller slipping side to side some which is making the noise. So could you please tell me what other parts I need besides the rollers? like maybe Roller shaft for drum support roller, right side ? etc..
miketieman
#4 Posted : Saturday, January 9, 2010 4:41:27 PM(UTC)
miketieman
The rollers will come in a kit. should have both rollers, shafts and any other misc. hardware.If you send me the model number of your machine i can get the part number you need and send it to you.
rmwalker41
#5 Posted : Tuesday, January 12, 2010 7:58:35 AM(UTC)
rmwalker41
the model # is LER5644ANO
miketieman
#6 Posted : Wednesday, January 13, 2010 4:53:50 AM(UTC)
miketieman
ok, for some reason your dryer does not have a full kit. The following are the part numbers you need: 349241T -- 2 pack of drum rollers. 3399506 -- shaft. 339489 -- shaft. There are 2 different size shafts hence the 2 part numbers. hope this helps.
