I am having the same problem with the identical microwave for a customer of mine. He replaced the motor on his own, but that did not fix the problem. So, he called me. I replaced the control board and the same problem is still there.
All door switches test good, all thermals are good. I have 120 volts to the HV transformer, but no neutral.
This microwave also has no wiring schematic. I am stuck. In 26 years of repairing microwaves, this ranks up there as one of the most frustrating problems I have seen.
I would suggest NOT replacing the control board just yet.
I am dead in the water on this one.
Originally Posted by: Matt S  I am having the same problem with the identical microwave for a customer of mine. He replaced the motor on his own, but that did not fix the problem. So, he called me. I replaced the control board and the same problem is still there.
I am dead in the water on this one. OK....here is what I found out and how I fixed my microwave. As you may recall the problem was intermittant. After being told it was the motor and after changing the $60 motor I found out the motor was not the problem. I was ready to do the control board, but at $200 or so I decidied to give things some more thought. The first thing I checked were all 3 door switched. All three checked ok. Could only be the control panel, right? Wrong. Remember the problem was intermittant and I was told to go back and check the door switched one more time. The guy even told me which one. Sure enough, when I checked the swith for the 5th time, it was bad. A $6 switch and I was back in business. It was the bottom swith I think. Best to all, Johnds
Thanks John!
Man, I sure hope that is it on this microwave.
Cheers!
Matt
Hello and thank you for writing. I hadn't yet tried to cross the Dacor DCM24S to its equivalent Sharp model yet, but it looks like it's the Sharp R930AK/AW. And as luck would have it, we have that full service manual online at all Microwave Display Repair Sharp Dacor GE General Electric Checking the schematic, your symptoms almost certainly indicate a defective secondary interlock switch (the bottom one) or its mount (door hook) may be loose or have a broken tab. You'd also need to be sure that the lower door latch head (the hooklike device on the door) is activating the lower switch when the door closes. It may be subtle, but I honestly feel it's a problem with the lower switch or associated wiring. I would call your attention to the following pages in the service manual: 11, 15, 26, 27, 31, 33. Bear in mind that the oven will not operate with the cover off unless you activate the outer case switch. See page 11. If it's a bad door switch, and your can't find one at a local appliance parts store, home improvement store (Lowe's or Home Depot, etc.) or Wal-Mart, you can get them from Tritronics at Consumer Electronics Parts and Accessories: Tritronics, Inc. If it's not a door switch, feel free to let me know what you find. Happy to help. William E. Miller, AS-EET prototech@usa.net † all Microwave Display Repair Sharp Dacor GE General Electric Microwave Oven Control Panel Repair Nationwide $39.95 Appreciate our help? Help us help others: all Microwave Display Repair Sharp Dacor GE General Electric
