melissac
#1 Posted : Sunday, January 10, 2010 3:02:36 PM(UTC)
melissac
LER5848EQ5 SECTION Parts
I'm having a problem getting my dryer to start. It was working fine, but then I dryed my down comforter. I thought that maybe it was clogged with lint so I:
Removed the back and vacuumed out all the lint.
Removed the excess lint from the duct.
Removed the lint from the lint trap (this was the only place I found any down)
Removed the top of the dryer and was able to pull the entire lint chute out - there was quite a bit of lint.
Removed the front cover & removed all the lint found under the drum.
Vacuumed the excess lint away from the motor.
I still can't get it to start. I turn the timer & push the on button and hear the small ticking sound its always made, but the switch does nothing.
From what I've been reading on the forum it could be a thermal fuse or a thermostat. It could also be that there's still lint around the motor (despite my vacuuming it)
I wonder if anyone has any ideas to help me. I also wonder when I replace these do I remove the drum & go through the front of the dryer, or can it be done from the back?
Here's a link I found to my parts if it helps at all.
And here's the model info
Model - LER5848EQ5
Serial - MH4619525
Type - 180-00
I think the dryer is about 11 years old. I've never had it serviced but I have noticed it doesn't dry as well as it used to - it seems to only work on high heat.
Thanks. Melissa
melissac
#2 Posted : Sunday, January 10, 2010 3:06:19 PM(UTC)
melissac
Oh I forgot to say, I've also tried resetting my breaker.
melissac
#3 Posted : Friday, January 15, 2010 1:05:22 PM(UTC)
melissac
I've called in the pros. I have a bad motor.
My new question is, is this a fairly easy do-it-yourself thing? I do all the plumbing & electrical work around the house, but haven't ever dealt with anything that has a motor.
I'm concerned about removing the drum with the belt & putting it back together.
Kenmore Dryer not turning on - hear timer clicking (Dryer Repair)
by Daibheid 6/16/2015 6:48:02 AM(UTC)
Dryer not turning on (Dryer Repair)
by rhschumaker 11/24/2013 11:31:38 AM(UTC)
kitchen aide dryer not turning on (Dryer Repair)
by dakota70 7/13/2010 12:23:39 PM(UTC)
Dryer Not Turning On (Dryer Repair)
by ANG1103 9/24/2009 2:37:49 PM(UTC)
whirlpool duet dryer not turning on-error code 3E (Dryer Repair)
by kmsewell 7/30/2009 8:22:35 AM(UTC)
Roper Dryer Not Turning On At All (Dryer Repair)
by 30tredog 9/23/2008 4:49:10 AM(UTC)
