30tredog
#1 Posted : Tuesday, September 23, 2008 4:49:10 AM(UTC)
30tredog
Yesterday i made a post about my roper dryer not running and the senior tech from liberty appliance told me i may need a thermal fuse the part no on the instruction manual is 3397618 I may need the part number of the thermal fuse, thank you
#2 Posted : Tuesday, September 23, 2008 12:11:12 PM(UTC)
In order to provide most accurate advise we need the complete model number of the dryer.
30tredog
#3 Posted : Tuesday, September 23, 2008 2:46:29 PM(UTC)
30tredog
i need a thermal fuse for Roper Model #RES7646Kq2 Serial #mm4430258
type dwjrele2406028fm54
#4 Posted : Tuesday, September 23, 2008 6:11:45 PM(UTC)
The thermal fuse is #7 on the break down diagram. It is recommended by the manufacturer to replace the cycling thermostat (next to the thermal fuse) too if the thermal fuse blown.
- The part number for the thermal fuse is AP3132867
- The part number for the cycling thermostat is AP3131939
Here are the break down diagrams for the Roper dryer Model RES7646KQ2
