appliance in storage for a year. working fine when i put it in. plugged in a couple of days ago not cooling. fan blowing warm air in freezer.
If the compressor is running then your looking at some type of sealed system problem, such as low or out of freon.
If the compressor is not running I would check for power at the start relay on the side of the compressor. If you have power to the start relay I would then replace the relay.
