Lost all power to microwave and display center.
Rank: Administration
Could be the fuse or the power supply board. If the fuse is bad, it usually means something else has shorted out and knocked out the fuse. Power supply board has been discontinued, as well as most of the components for this model.
Originally Posted by: colonialfan Lost all power to microwave and display center. but the clock still works and the cook top Gas does not come on
Originally Posted by: Admin / APP Team Could be the fuse or the power supply board. If the fuse is bad, it usually means something else has shorted out and knocked out the fuse. Power supply board has been discontinued, as well as most of the components for this model. Can you tell me where I could fine a power board if thats what I need? HELP
Originally Posted by: conniemyhre Can you tell me where I could fine a power board if thats what I need? HELP or do I have to buy a new stove
Originally Posted by: conniemyhre Can you tell me where I could fine a power board if thats what I need? HELP or do I need to buy anew stove
