Got new sensors, found the old ones just inside the door - can't figure out how to get old ones out without breaking something??:confused:
Hi autoxracer
What exactly is the problem with your dryer? The moister sensor is the last part I"ll replace. It never breaks. Post your problem and I might be to help you.
Dryer stops running before clothes are dry when on a moisture type setting. Gets plenty hot during the cycle? So I believe it is not reading moisture content correctly.
