autoxracer
#1 Posted : Sunday, August 19, 2007 9:19:41 AM(UTC)
autoxracer
Got new sensors, found the old ones just inside the door - can't figure out how to get old ones out without breaking something??:confused:
#2 Posted : Monday, August 20, 2007 10:41:41 AM(UTC)
Hi autoxracer
What exactly is the problem with your dryer? The moister sensor is the last part I"ll replace. It never breaks. Post your problem and I might be to help you.
autoxracer
#3 Posted : Monday, August 20, 2007 4:22:23 PM(UTC)
autoxracer
Dryer stops running before clothes are dry when on a moisture type setting. Gets plenty hot during the cycle? So I believe it is not reading moisture content correctly.
#4 Posted : Tuesday, September 4, 2007 7:04:42 PM(UTC)
Hi autoxracer
I'm sorry for the delay.
The complete instructions how to diagnose and fix your Amana dryer Model ALE866SAW you can find here.
- Here are the break down diagrams
Good luck.
moisture sensors gone bad? (Dryer Repair)
by campbell42 4/7/2019 2:28:27 PM(UTC)
