Brandon
#1 Posted : Thursday, March 6, 2008 10:47:06 AM(UTC)
Brandon
How much residual water is normal inside the washer after it has completed all cycles? After removing clothes from the washer, I spun the barrel and it sound as if there is a significant amount of water still in the tub. Do I need to replace the drain motor? Or is there something else I need to be looking for?:confused:
cds
#2 Posted : Friday, March 7, 2008 11:43:31 AM(UTC)
cds
The noise you hear is probably the solution of calcium chloride in the balance ring located on the front of the spin basket assembly. That is a normal sound. See section 7-3 of the manual for your washer.
Residual Water remaining after Cycle is complete (Dishwasher Repair)
by jimgilbert 9/15/2011 8:17:57 PM(UTC)
draining residual water from washing machine in order to move it (Washer Repair)
by grannybananny99 10/13/2009 8:14:35 AM(UTC)
