lcoyle
#1 Posted : Tuesday, January 5, 2010 12:09:36 PM(UTC)
lcoyle
9.5 burner ignitor won't spark or light at all. Can I get just an electrode to replace it? Is it easy to replace or does it require a professional?
#2 Posted : Tuesday, January 5, 2010 1:23:57 PM(UTC)
Quote:
...9.5 burner ignitor...
What is "9.5"?
lcoyle
#3 Posted : Tuesday, January 5, 2010 3:52:32 PM(UTC)
lcoyle
9.5K (btu burner size) it is the front burner. Currently the gas supply is fine, the ignitor is tempermental and only works when it wants.
What is "9.5"?
#4 Posted : Tuesday, January 5, 2010 6:12:18 PM(UTC)
Does it click and/or spark when you turn this burner "On"? Does it spark when you turn "On" any other burner?
lcoyle
#5 Posted : Tuesday, January 5, 2010 6:42:13 PM(UTC)
lcoyle
It was not sparking or clicking when any burner was turned on. But at thte moment it is sparking and turning on since I gave it a heavy cleaning with windex. does that make any sense?
#6 Posted : Tuesday, January 5, 2010 6:59:20 PM(UTC)
Yes, if the burner igniter is wet or greasy - it will never work properly. Also it's important to keep the burners clean as well.
Guest (4)
oven wont ignite after replacing ignitor (Oven Repair (including Ranges and Cooktops))
by tim3768 8/14/2012 2:42:06 PM(UTC)
Replacing ignitor on GE Dryer (Washer Repair)
by hgbcpa 3/7/2012 3:34:08 PM(UTC)
oven still won't light after replacing ignitor kit (Oven Repair (including Ranges and Cooktops))
by neilcZSGJ39 1/27/2012 4:10:09 PM(UTC)
help replacing ignitor (Oven Repair (including Ranges and Cooktops))
by jcurat 2/23/2009 5:35:49 PM(UTC)
replacing ignitor (Dryer Repair)
by randyf 7/7/2008 12:53:22 PM(UTC)
Gas Oven - REPLACING IGNITOR (Oven Repair (including Ranges and Cooktops))
by tri3 1/7/2008 4:10:19 PM(UTC)
