pullmyfinger
#1 Posted : Wednesday, March 5, 2008 6:39:12 AM(UTC)
pullmyfinger
Help! My Frigidaire won't drain after the wash cycle is complete. It was installed in 2002, I have not installed a new disposal, & the is no obstructions. I replace the drain valve & solonoid to no avail. Any ideas? :confused:
#2 Posted : Wednesday, March 5, 2008 5:10:27 PM(UTC)
What did you replace? I did not find the drain valve nor the solenoid on your dishwasher parts list.
I would recommend to remove the drain pump and check it and the drain hose for a clog.
Here are the break down diagrams for the Frigidaire dishwasher Model FDB635RFR5
pullmyfinger
#3 Posted : Thursday, March 6, 2008 4:53:15 AM(UTC)
pullmyfinger
I'm an idiot Gene! I found a blockage. Appeared to be mashed potatos! It was the drain pump I replaced (for nothing). Thanks for the help!
#4 Posted : Thursday, March 6, 2008 9:41:50 AM(UTC)
I'm glad you were able to fix it.
frankASR
#5 Posted : Saturday, March 8, 2008 1:24:18 PM(UTC)
frankASR
mine always leaves water up to the heating element after com[pleted cycle ,checked loop ,it looks fine,havent checked filter or pump,does it have a filter? is it that round part in bottom with vents around? insine of tub?..... help please
frank
#6 Posted : Sunday, March 9, 2008 1:56:16 PM(UTC)
Hi Frank,
In order to provide most accurate advise I need the complete model number of the dishwasher.
pullmyfinger
#7 Posted : Monday, March 10, 2008 9:26:26 AM(UTC)
pullmyfinger
Like mine, you might not see the obstruction. Take the hose off at both ends & try blowing air through the line. If you can't, obviously you have a blockage. Don't do what I did though! Drain as much water out of the unit before you disconnect it at the dishwasher! This way you won't end up with water all over the floor & dripping into the basement!
Whirlpool Dishwasher Won't Drain Completely, I hear Pump Running... (Dishwasher Repair)
by Guest 4/18/2022 5:39:50 PM(UTC)
Bosch SHU33 dishwasher won't drain when hot just after a wash (Dishwasher Repair)
by Guest 7/12/2021 7:43:33 AM(UTC)
Bosch dishwasher won't drain, begins cycle, then stops - FIXED (Dishwasher Repair)
by mabradbury 1/17/2019 7:08:25 PM(UTC)
Bosch dishwasher won't drain completely (Dishwasher Repair)
by nathaniel.hoffman@gmail.com 12/25/2018 6:30:47 AM(UTC)
GE dishwasher won't drain after last rinse cycle (Dishwasher Repair)
by autotech1 1/22/2018 9:47:40 AM(UTC)
Dishwasher won't drain (Dishwasher Repair)
by Drummabouy 6/22/2017 6:29:14 AM(UTC)
Dishwasher Won't Drain or Run Cleaning Cycle (Dishwasher Repair)
by Katie L 8/4/2016 2:07:24 PM(UTC)
Bosch Dishwasher won't drain and goes directly to "Clean" Light (Dishwasher Repair)
by ed3120 6/4/2016 4:40:01 AM(UTC)
by brokenge 2/18/2016 2:32:59 PM(UTC)
Frigidaire dishwasher won't drain (Dishwasher Repair)
by kohanz 12/4/2015 9:35:55 PM(UTC)
Dishwasher won't drain! (Dishwasher Repair)
by Crafter_Man 10/12/2015 4:30:35 AM(UTC)
GE Dishwasher won't drain all way (Dishwasher Repair)
by AnthonyJS02 1/10/2015 9:12:07 AM(UTC)
by av0612 8/6/2014 4:42:36 PM(UTC)
Frigidaire Gallery Series Dishwasher won't drain fully after disposal replacement (Dishwasher Repair)
by wicked94pgt 7/17/2014 7:31:44 PM(UTC)
GE Dishwasher won't drain (Dishwasher Repair)
by crabbygardener 6/10/2014 6:30:07 PM(UTC)
