2 Pages<12
#11 Posted : Wednesday, March 5, 2008 4:12:29 PM(UTC)
Well, just break it off and replace with a new part. I do not see what else could be done?
skip
#12 Posted : Tuesday, March 11, 2008 1:43:04 PM(UTC)
skip
Hello Again Gene -
The replacement parts (for the jammed spray arm hub and wash arm assembly) came today and I installed them. Sadly the dishwasher still trips the breaker - it will run through a complete cycle of "Rinse Only" but trips early in any of the wash cycles - soon after the unit is filled with water. Does this info give you any clue as to what might be wrong?
#13 Posted : Tuesday, March 11, 2008 3:55:52 PM(UTC)
Looks like there is a problem in the heating circuit.
You have to check the heating element, the hi limit thermostat and the corresponding wires for a short to ground.
skip
#14 Posted : Tuesday, March 11, 2008 4:14:55 PM(UTC)
skip
Thanks Gene - will do
Guest (5)
2 Pages<12
