BIPD818
#1 Posted : Sunday, January 3, 2010 11:30:27 PM(UTC)
BIPD818
My 10-year-old Viking range/oven 30", 4 burner, LP, gas oven/broiler intermittently won't light or won't cycle back on during baking. Both glow igniters come on, but no gas. If I bang on the gas valve, both burners light immediately. I assume I have a sticky valve (dual valve, LP gas). I don't know the model number. Any suggestions for a universal replacement?
#2 Posted : Monday, January 4, 2010 2:21:11 AM(UTC)
Are you saying both bake and broil igniters glow at the same time??
BIPD818
#3 Posted : Monday, January 4, 2010 2:18:20 PM(UTC)
BIPD818
No, the oven has two burners plus the broiler. The broiler works fine and appears to have a separate igniter and safety valve. The two main burners have individual igniters and share a dual valve safety valve. It is these two main burners that won't light after the igniters are glowing, until I tap on the dual valve and then both burners light immediately.
Thanks.
#4 Posted : Monday, January 4, 2010 2:58:17 PM(UTC)
These flat igniters must draw more than 3 amps to activate the gas valve. Your igniters may be only supplying less than 3 amps. I would just order the igniters, rather rare these gas valves fail. Check the current to confirm.
BIPD818
#5 Posted : Monday, January 4, 2010 10:09:23 PM(UTC)
BIPD818
Thanks, I'll throw an Amp meter on it to see if there is 3+ amps.
jepetrick
#6 Posted: : Monday, December 30, 2013 11:32:56 AM(UTC)
jepetrick
It would be so nice to hear if that worked?
Guest
#7 Posted : Monday, August 21, 2023 10:58:09 AM(UTC)
Guest
Rank: Guest
United States
Same issues..I knock on valve and second burner light up..safety valve issues ??
