Frank_Rizzo
#1 Posted : Friday, January 1, 2010 10:26:30 AM(UTC)
Frank_Rizzo
I have general questions on bottom freezer GE profile.The damper door wont stay open, what can be the cause and what should i check for? does the refrigerator thermistor play a role on opening/closing damper door or just the main board?On defrost problem, if i change main board should i also change freezer thermistor?any help will be appreciated.
applianceman
#2 Posted : Friday, January 1, 2010 6:27:21 PM(UTC)
applianceman
On these GE electronic refrigerators there is what they call a liner protection mode, which turns on the fans and closes the damper when the door is opened for more than three minutes. I am almost sure the bottom freezers are the same way. The damper will close if the door is opened for more than three minutes. Check the door switch to see if it is operating correctly i.e. does the lights turn on and off when the door closes and opens.
The thermistors and the main control the damper.
There is a picture on this page to identify thermistors that were prone to failure. It also tells how to test the thermistors for accuracy. GE Refrigerator Repair Guide
Thermistors cause more problems than the main boards as regards with a defrost problems but the main board is the only thing that can cause both problems you are having. If you haven’t already done so be sure to check the defrost heater before you replace the main board. Hope this helps!!
Frank_Rizzo
#3 Posted : Saturday, January 2, 2010 3:51:16 AM(UTC)
Frank_Rizzo
Thank you for the response. yes it was very helpful.
Strange problem with GE profile bottom freezer (Refrigerator & Freezer Repair)
by rwild1967 10/15/2014 1:08:04 PM(UTC)
Ge Profile Bottom freezer - temperature reading for the fidge off 30 degrees (Refrigerator & Freezer Repair)
by chorton 5/30/2014 1:27:25 AM(UTC)
GE Profile Bottom Freezer, top Ice maker issue (Refrigerator & Freezer Repair)
by JDixon85 2/25/2014 10:24:46 AM(UTC)
GE Profile Bottom Freezer - Freezing Veggies in Crisper (Refrigerator & Freezer Repair)
by tubby 7/11/2011 5:52:33 AM(UTC)
Refrig Freezing food, Temp Display probs, GE Profile Bottom Freezer (Refrigerator & Freezer Repair)
by GardenHound 7/12/2010 10:33:29 AM(UTC)
GE Profile Bottom Freezer (PFS22SISBSS) (Refrigerator & Freezer Repair)
by cfipilot99 12/17/2008 8:12:46 PM(UTC)
GE Profile Bottom freezer horrible noise/heat (Refrigerator & Freezer Repair)
by Lois 8/6/2007 7:11:14 PM(UTC)
