Slash8789
#1 Posted : Sunday, November 23, 2008 5:19:47 PM(UTC)
Slash8789
Hi all. I searched for the answer before I posted but could not find anything. I hope I did it right.
Here is my problem: I have a Frigidaire slide-in cooktop model# FES365ESB. I think it is made by Electrolux? It has a 6"/9" expandable element located at the front/right. I think it is also called a dual radiant element? Anyways, The inside element (6-inch) does not turn on at all. I can turn on the outside (9-inch) one. Does anyone have any idea on what this could be?:confused:
I have worked on standard coil element oven ranges but never a cooktop. If I decide to tackle this project I hope I can find the answers here. I'm gonna have to. I can't afford to have it repaired.:(
Thank you to all.:)
sfox
#2 Posted : Thursday, December 31, 2009 3:03:43 PM(UTC)
sfox
I have the same problem with my Frigidaire slide-in cooktop model# FES365EQ. It's just over 1 year old.
Is this the switch problem or the Radiant (heating element) problem?
Appreciated. Thank you.
#3 Posted : Sunday, January 3, 2010 5:55:07 AM(UTC)
Replacement parts for FES365EQ models | AppliancePartsPros.com
Here is the wiring diagram
http://manuals.frigidaire.com/p...assomption/318271958.pdf
Only way to tell what is gone is to remove the element from the unit and check it with a meter. If it is OK then the probable cause is the control.
Unless of coarse there is a bad connection going to that element.
