BobW
#1 Posted : Monday, March 3, 2008 1:35:22 PM(UTC)
BobW
I purchased a Kenmore double door (w/ice maker and water dispenser)
refrigerator in 2004. Lately, it has been making a da, da, da, da, da, noise,
off (3 or 4 times per day)and on, usually late at night or early a.m
hours and for only a few seconds (up to 30)each time. The noise coincides
with the water dispenser dispersing water irregularly. The noise stops
and the water returns to normal when I open the refrigerator side
door, not the freezer side. My filter is about 4 months old. Could this be
a filter problem causing this?
#2 Posted : Tuesday, March 4, 2008 1:00:17 PM(UTC)
Did you remove a couple of gallons of water (through the dispenser) after you replaced the filter last time? Sounds like there is an air inside the system.
For more accurate advise I need the complete model number of the fridge.
BobW
#3 Posted : Tuesday, March 4, 2008 1:19:53 PM(UTC)
BobW
Gene:
Thank you for your reply. I removed only 5 or 6 full glasses of water before I started using it. Model number is Kenmore 10644109300.
#4 Posted : Tuesday, March 4, 2008 1:55:52 PM(UTC)
Bob,
Remove more water and check the water tank (on the bottom in the fresh food compartment) for any small crack.
BobW
#5 Posted : Friday, March 7, 2008 12:19:51 PM(UTC)
BobW
Thanks Gene for all of your help. I removed more water. It seems to be working fine now.
#6 Posted : Friday, March 7, 2008 2:44:45 PM(UTC)
I'm glad you were able to fix it.
