bobworthy
#1 Posted : Monday, March 3, 2008 12:26:17 PM(UTC)
bobworthy
FREEZER TEMP GOES UP ABOVE 32 DEGREES LONG ENOUGH TO THAW FROZEN ITEMS. ICE MELTS AND RE-FREEZES IN ONE LUMP. HOW DO I GO ABOUT CHECKING THE DEFROSTER TIMER AND/OR THE THERMOSTAT? I HAVE WORKED ON A LOT OF DIFFERENT APPLIANCES BUT NOT REFRIGERATORS.
:confused:
#2 Posted : Tuesday, March 4, 2008 12:11:56 PM(UTC)
Most likely the cause of the problem is a stuck close defrost thermostat (#21 on the system break down diagram).
Remove the back panel in the freezer and check the defrost thermostat for continuity when there is no frost. Replace if it's closed.
- The part number for the defrost thermostat is AP2150024
Here are the break down diagrams for the Frigidaire refrigerator Model FRT21INLHW0
