woncman
#1 Posted : Friday, December 25, 2009 7:44:38 AM(UTC)
woncman
First of all - Merry Christmas and Happy Holidays to all. I had some downtime before the family arrives, so I'd thought I post this.
We have a whirlpool LA5667XTW1 washer that's getting up there in age. The washer was working perfectly until it started vibrating badly during a cycle. I stopped the machine to make sure the load was balance and checked the front foot pads to make sure it was still level. I went to restart the machine and there was no power (It had tripped the circuit breaker).
I reset the breaker, and there is power to the outlet, but the washer won't do anything. (Won't fill, spin, anything). Is it possible that I blew some sort of internal switch or anything else?
Due to the age of the washer, I really don't want to drop $150 just to have the Whirlpool guy come and look at it and tell me its some expensive part that I need (I'd rather get a new washer) But If I can fix it cheaply, that would obviously be prefered.
If anyone can point me in the right direction, I would appreciate it.
Thanks!
#2 Posted : Friday, December 25, 2009 2:08:55 PM(UTC)
The first thing I would do is open the control panel, remove the cover from the timer and check all terminals for burned spots.
- The timer Part number: AP3099903
Here is the wiring sheet.
Here are the breakdown diagrams and Replacement parts for WHIRLPOOL LA5668XTW1 | AppliancePartsPros.com
#3 Posted : Saturday, December 26, 2009 1:55:53 AM(UTC)
If the washer motor will not run, I would suspect a bad motor or a motor connector or wire has come loose, just pull outer cabinet and check.
