dp1313
#1 Posted : Wednesday, December 23, 2009 2:02:01 PM(UTC)
dp1313
I just replaced the spark module on my Thermadore SGCV36G Cooktop because all of the igniters were constantly clicking. I also cleaned(w/o water) and checked everything. Now when I turn on 1 or both of the left side burners they work fine but when I turn on just 1 right side burner all of the igniters click and if I turn on both right side burners the clicking stops. If you have any ideas what is wrong I would appreciate it.
kayakcrzy
#2 Posted : Thursday, December 24, 2009 5:04:42 AM(UTC)
kayakcrzy
It sounds like one of the micro switches on the right side is shorted out. If the left side works fine, I would replace the 2 on the right. One of them are bad, and there is no need to guess. The microswitches are cheap. Replace the 2 on the right. If you do not know what the micro switch is, it sits down on top of the burner switch, and there are 2 wires that come to them. Let me know how it goes. Tom ApplianceEducator.com - Parts
dp1313
#3 Posted : Thursday, January 7, 2010 6:56:56 PM(UTC)
dp1313
Thanks for the reply. You said those switches are cheap but this site list them as $20,is that right? Also the switch seems pretty simple,it is either open or closed,am I missing something?
kayakcrzy
#4 Posted : Friday, January 8, 2010 3:52:00 AM(UTC)
kayakcrzy
Nothing wrong with the price. What happens is when a switch is bad, and you turn on another switch, the bad switch gets the power going through it when it shouldn't. Tom ApplianceEducator.com
More igniter problems (Oven Repair (including Ranges and Cooktops))
by dp1313 12/5/2009 2:24:23 PM(UTC)
GE Cooktop Igniter problems (Oven Repair (including Ranges and Cooktops))
by KatyTx 12/27/2008 7:27:46 PM(UTC)
