Bendelw
#1 Posted : Monday, December 21, 2009 4:10:37 PM(UTC)
Bendelw
water through door doesnt work water line freezes inside I have replaced the defrost heater and defrost thermostat. Immediate reply please. :confused:
woodchuckie
#2 Posted : Monday, December 21, 2009 4:42:49 PM(UTC)
woodchuckie
This is a common problem with GE. It doesn't have anything to do with the defrost components. They make a heater to put in the dispenser to correct the problem. The part number for this heater is WR49X10173. Part Details - GE DISPENSER WATER TUBE, part number: AP4318572
Bendelw
#3 Posted : Monday, December 21, 2009 5:08:02 PM(UTC)
Bendelw
Where does that part go and how hard is it to replace? DISPENSER WATER TUBE
Part Number: AP4318572
Manufacturer's Number: WR49X10173 made by GE
And is this one of the recall parts GE is offering to replace?:confused:
How does one go about removing the front the door?
woodchuckie
#4 Posted : Monday, December 21, 2009 6:53:53 PM(UTC)
woodchuckie
It would be worth it to call GE about replacing it. All I know is that they have replaced some. The heater goes near the line that can reached from the dispenser. Instructions come with it. You can take the door off by removing the hinge hardware letting the magnetic gasket hold the door and disconnecting the water and wires at the bottom of the door.
Bendelw
#5 Posted : Monday, January 25, 2010 4:31:57 PM(UTC)
Bendelw
I was told that my problem with water freezing in door tube could be repaired by installing part # ap4318572 which is called dispenser water tube heater, I was going to order this part but they told me that it doesnt come with instructions. Could you tell me how to instal this part before I order the part. refrigator model # is GSS20IEPCWW serial # is 256955 and it is a GE refrigator.
