bbrown61
#1 Posted : Thursday, December 10, 2009 10:54:46 AM(UTC)
bbrown61
My maytag frig has developed a buzzing and then a click sound. It cools and freezes fine. It seems to do it at the same time every day. Goes on
for about half an hour. I thought that it seems like the defrost timer. Any help would be greatly appreciated.
thanks
#2 Posted : Friday, December 11, 2009 5:49:14 AM(UTC)
Here are the parts
Replacement parts for MAYTAG PBF2253HEW Ref - Bottom Mounts | AppliancePartsPros.com
You do not have a defrost timer, defrost is controlled from the main control board.
It could be the defrost relay on the board buzzing.
Could be the evaporator defrost heater vibrating and then the click may be the defrost thermostat opening.
bbrown61
#3 Posted : Friday, December 11, 2009 10:12:08 AM(UTC)
bbrown61
Would that be pn AP4366538? I see that it shows the location as behind the temp controls. Since the noise comes from under the frig, would that
relay control the t-stat under the frig?
#4 Posted : Friday, December 11, 2009 12:14:01 PM(UTC)
Yes
Since the noise comes from under the frig, would that relay control the t-stat under the frig?
No.
You will have to pull the fridge out and try to isolate the noise.
The heater and the defrost heater thermostat are down there but the are inside the freezer compartment.
There is a start relay on your compressor but your compressors etc. seems to be running OK.
Here are a couple good sites withe fridge info
http://www.applianceaid.com/frig.html
Refrigerator Repair Guide: How To Fix a Refrigerator - ACME HOW TO.com
bbrown61
#5 Posted : Monday, December 14, 2009 4:53:14 AM(UTC)
bbrown61
The noise is coming from underneath the frig near the front.
#6 Posted : Monday, December 14, 2009 5:16:20 AM(UTC)
Well I'm stumped
All I can think of is that perhaps the condenser coils are vibrating. Remove the kick plate ans see if you can gently push down on the coils to see if the noise stops.
Only other thing I can think of is the water valve is buzzing and resonates so thet it sound like it is coming from the front.
bbrown61
#7 Posted : Saturday, December 19, 2009 9:46:20 AM(UTC)
bbrown61
Originally Posted by: denman Go to Quoted Post
Well I'm stumped
the part that is buzzing looks like it is plugged into the compressor. it continues to cool fine. it does not buzz everytime the comp kicks on
bbrown61
#8 Posted : Saturday, December 19, 2009 9:53:25 AM(UTC)
bbrown61
would that be the capacitor? pn ap4074064. does it plug in and its held by a spring clip
#9 Posted : Saturday, December 19, 2009 5:27:32 PM(UTC)
Yes it is Item 8 in Section 3
More likely that the relay is buzzing Item 4 i Section 3
Guest (4)
