wedge1
#1 Posted : Saturday, December 19, 2009 7:36:38 AM(UTC)
wedge1
Hi i need help with a thermal cut-off problem,:( my dryer stopped heating up on all settings so i set too and cleaned the thing inside but still not working, the drum rolls but no heat. so i tested all the parts i could and got continuity on all parts but the thermal cut off. so i replaced this part and the dryer worked for a few minutes then stopped heating again. on returning to the same part it failed the continuity test, so something else is causing the part to fail.
any thoughts would be welcome :)
#2 Posted : Saturday, December 19, 2009 1:00:40 PM(UTC)
A Model Number may help others help you.
Am not sure but I am assuming the thermal fuse you are referring to is the one on the heating assembly.
I would check the heater for a grounded element.
Remove both wires from the heater and measure it, should be around 10 ohms.
Then measure from each connector to the heater case, both should be infinity (open).
Also check that there is no flash marks on the inside of the heater case, as sometimes the coil can sag when hot and touch the case,
What happens is the heater can ground out and depending where/how it grounds it will run on high heat, the thermostats cannot regulate the heat and it will blow the fuse.
It is a good policy to replace both the fuse and the hi-limit as the hi-limit should have regulated the temperature so the fuse did not blow.
I would also check the unit's drum seals etc. The regulating thermostat is on the blower assembly so if there is a large air leak somewhere room air is sucked in. The thermostat then causes the unit to run on high heat and never turn off.
You may want to also check the operating thermostat. Remove it, place it on a stove element heat it up till you hear it open and then measure it. If it does not open it's contacts are welded together. Be careful you do not burn yourself. I just heat them up with my soldering gun.
As usual when a thermal fuse blows give the interior a good cleaning including the blower wheel. Also check/clean your vent system.
wedge1
#3 Posted : Saturday, December 19, 2009 4:12:33 PM(UTC)
wedge1
Hi
No its not the fuse on the actual heater element but the stand alone switch above this that just has the two wires coming out.:)
Thanks for your help
#4 Posted : Saturday, December 19, 2009 5:16:41 PM(UTC)
Model Number?
Model Number Locator
wedge1
#5 Posted : Sunday, December 20, 2009 7:15:16 AM(UTC)
wedge1
Originally Posted by: denman Go to Quoted Post
Model Number?
Whirlpool LEB6000PQ1
#6 Posted : Monday, December 21, 2009 1:44:41 AM(UTC)
Bulkhead parts, optional parts (not included) replacement parts for WHIRLPOOL LEB6000PQ1 29" Electric Dryer | AppliancePartsPros.com
OK fuse is Item 6 in Section 3, my first post will be applicable.
Click on it's item picture for a better view.
Here is the wiring diagram that should be useful
http://www.servicematters.com/d...0Sheet%20-%208576793.pdf
wedge1
#7 Posted : Monday, December 21, 2009 5:44:36 AM(UTC)
wedge1
Thanks fuse ordered will let you know results :cool:
Whirlpool dryer thermal cut-off (Dryer Repair)
by cjwojcik 5/29/2011 1:22:10 PM(UTC)
