Replacement parts for WHIRLPOOL GEW9250PW0 ELECTRIC DRYER | AppliancePartsPros.comSee the attachment for the tech sheet.
We may have a semantics problem.
The thermal fuse (Item 59 in Section 3) kills power to the motor.
From your post it sounds like this is OK.
The most common cause of this blowing is a dirty or malfunctioning vent system.
The thermal cut-off (Item 47 in Section 3) kills power to your heating coil.
Here is my usual blurb if this one is blown.
Check the heating coil.
Unplug the unit and both wires to the coil.
Check it with a meter, should be around 8 to 12 ohms.
Then check from each side of the coil to the case/frame, both should be infinite ohms (open). If not the coil may have sagged or broken and is touching the case (grounded). This can cause it to run on high and the thermostats cannot regulate it so the thermal cut-off blows.
The hi-limit should have regulated the temperature so the fuse did not blow, that is why there is a new one with the thermal cut-off..
Note: That unless there is another problem in the unit the hi-limit should never have to open. It is just a safety device with the fuse being a backup safety device.
Just in case it is not a grounded element.
With all the below the high limit will also have to be replaced.
Check that the belt is OK.
Check the seals (drum etc) in the unit. The air is pulled over the heating coils, through the drum and pushed out the exhaust. So any large seal leak will pull in room air and the cycling thermostat on the blower will run the unit hot.
Check that the lint filter is not coated with fabric softener residue which greatly reduces air flow.
Check/clean your vent system.
Check/clean the blower wheel.
If all OK you may want to check the thermistor for resistance.
Also there is a possibility that it could be the control board.
I am guessing that you may have had a grounded element. This blew the thermal fuse and perhaps the thermal cutout. You then replaced these.
It then blew the thermal cutout. Now that the heating coil has been replaced perhaps all you need is a new thermal cutout.
The above is just a guess on my part.
