4 Pages123>»
michaelmag
#1 Posted : Thursday, February 7, 2008 3:34:27 PM(UTC)
michaelmag
I purchased from this site and installed two new door hinges, part no. AP368960. Seemed very simple. But the door doesn't close tightly. Not even tight enough to push the button to turn the oven light off. I've taken it off and reinstalled it but can't see what might be wrong.
#2 Posted : Thursday, February 7, 2008 4:22:36 PM(UTC)
Most likely the problem caused by the door hinge receptacles (#6 on the body break down diagram).
Replace the receptacles if there is not possible to adjust them.
- The part number for the door hinge receptacle is AP4090071
Here are the break down diagrams for the Jenn Air oven Model SVD48600P
michaelmag
#3 Posted : Monday, February 11, 2008 7:58:11 AM(UTC)
michaelmag
golly, my oven doesn't look exactly like that. Are those "receptacles" the pins that the hinges hang on inside the body? behind the hinge retainer and the hinge cover, items 10 and 11? Thanks
#4 Posted : Monday, February 11, 2008 8:47:46 AM(UTC)
The break down diagrams, I referred to, are corresponding to the model number you posted. On other side this is not a picture - just a schematic.
You were right. The hinge receptacle is an assembly of a couple of pins that the hinge hang on inside the body and it is behind the hinge retainer and the hinge cover.
rpdugan
#5 Posted : Friday, February 29, 2008 5:35:55 PM(UTC)
rpdugan
I have this exact same problem on this exact same model, the SVD48600P. I just recieved my second set of hinges...and I have the same problem. Just does not close tightly? What can be wrong with the pins?? Especially, if the original hinges closed fine? Is it possible that the new hinges are just not made the same as the old ones?
Did the above advice fix your problem???
rpdugan
#6 Posted : Friday, February 29, 2008 5:58:54 PM(UTC)
rpdugan
I recieved this part from Maytag...71003351. Is this the same hinge as the AP386960 hinge, or did they send me the wrong hinge?
rpdugan
#7 Posted : Friday, February 29, 2008 6:20:34 PM(UTC)
rpdugan
I checked my recpeticals...they look brand new...tight as a drum. I really do not think this is the problem. There is also no way to adjust them...
I think the new hinge is just slightly different that the original...which is a real problem as my door does not close....
#8 Posted : Friday, February 29, 2008 8:40:45 PM(UTC)
Hi rpdugan,
The correct Maytag part number for the door hinge for your oven is 71003353 which crosses over to the APP part number AP368960.
rpdugan
#9 Posted : Friday, February 29, 2008 9:00:12 PM(UTC)
rpdugan
So, I have the wrong hinge??? Pretty sure about that? That would sure answer my problem...
rpdugan
#10 Posted : Monday, March 3, 2008 6:34:59 PM(UTC)
rpdugan
the first set of hinges I got was the part ending in the 3... Still not working right...
Guest (20)
Frigidaire oven door hinge not locking (Oven Repair (including Ranges and Cooktops))
by jacobrobbins219 3/16/2021 5:42:08 PM(UTC)
Where Online Can I Find Compatible DCS (Fisher & Paykel) Oven Door Hinges? (Refrigerator & Freezer Repair)
by WestLA 8/19/2019 10:57:44 AM(UTC)
No lockouts on Gas oven door hinges (Oven Repair (including Ranges and Cooktops))
by sendto 3/16/2018 8:49:42 AM(UTC)
Oven door hinges (Oven Repair (including Ranges and Cooktops))
by prcummings 1/20/2018 3:29:04 PM(UTC)
help with oven door hinge replacement (Oven Repair (including Ranges and Cooktops))
by rick.bain@ferguson.com 4/5/2014 4:20:31 PM(UTC)
Replace Oven Door Hinge (How to) (Oven Repair (including Ranges and Cooktops))
by Tory022 11/8/2013 7:34:27 AM(UTC)
Oven door hinge access on older Magic Chef (Oven Repair (including Ranges and Cooktops))
by sparkyguy 10/17/2013 5:42:59 PM(UTC)
by llfraser 6/14/2013 7:19:47 AM(UTC)
by Ovenblues 4/12/2013 10:39:26 AM(UTC)
Replace GE oven door hinge (Oven Repair (including Ranges and Cooktops))
by C. Renaldo 12/28/2012 7:21:26 AM(UTC)
Whirlpool Oven Door Hinges Continuously Fail (Oven Repair (including Ranges and Cooktops))
by togamac 10/4/2012 8:50:36 AM(UTC)
GE Oven door Hinge - what is wrong? (Oven Repair (including Ranges and Cooktops))
by margot10 7/20/2012 7:00:24 AM(UTC)
Maytag oven door hinges replacement (Oven Repair (including Ranges and Cooktops))
by dennispandolfino 7/11/2012 2:25:00 PM(UTC)
How to remove oven door hinge after door is removed? (Oven Repair (including Ranges and Cooktops))
by stilllearning6 4/15/2012 11:14:40 AM(UTC)
oven door hinge no longer available (Oven Repair (including Ranges and Cooktops))
by itsnotrequired 6/20/2011 9:56:29 AM(UTC)
4 Pages123>»
